Page 1 of 1
For the Gar-Raj
PostPosted: Mon Feb 02, 2015 9:56 am
by Tom
Re: For the Gar-Raj
PostPosted: Mon Feb 02, 2015 11:00 am
nice.
On the list is a lift.... just need to pull get fully set up before adding to the mess.
Im leaning towards a mid rise scissor... like this
http://www.gregsmithequipment.com/Atlas ... issor-Lift
I figured it would make dropping the VW engine cake walk. And swapping rims and tires a breeze. Also need to be able to lift a full size Pick up as needed ( brakes a tires swaps etc)
Thoughts?
Re: For the Gar-Raj
PostPosted: Mon Feb 02, 2015 11:03 am
by Glenn
This is all you need for a VW.
But if you're gonna lift the Tundra, you need a 2 post bolted to the floor. $$$$
Re: For the Gar-Raj
PostPosted: Mon Feb 02, 2015 11:19 am
Glenn wrote:This is all you need for a VW.
Yes and no. I think the mid rise lifts are rated at 6k lbs, and the Tun weights 6k.
Re: For the Gar-Raj
PostPosted: Mon Feb 02, 2015 11:46 am
by Tom
I don't know, that doesn't look very stable.
Re: For the Gar-Raj
PostPosted: Thu Feb 19, 2015 6:19 pm
by VwJay
Two post lifts are the way to go. If its an asymmetrical which most of the better ones are you have to back a bug up to get the arms in the proper spaces to lift it. There's almost no spot I can't easily access on a bug with one. And mines rated to 12.5k lbs. little bit better than 6k. I paid $$$ up front for it. But I've made my money back and then some.
