Re: End of the season
More chrome, more gooder.
Slam that biotch on earlies.
Dropped the crates off at Yellow Freight and Forward Air. Thanks to Jim Lynch for helping with the trailer and the heavy lifting.
type 2 Jim Lynch is the man.
I cleaned up my axles today and found one of the CV boots torn and the other on the same axle has cracks. Both on the other side are fine. I'm a bit surprised since they are all 5 years old.
Time to clean the CV, replace the boot and repack with grease.
Crappy photo but you can see some of the cracks.
Post by volksbugusa »
The rubber replacement products today are so sensitive to our environment. They just do not hold up.
I am always spraying down my ball joint boots with silicone to slow down the cracking process.
Your axel boots are a real pain to change. But at least when you are done they won’t leak 
Matt,
I've done them before so I know what i'm in for. The one with the torn boot needs to disassembled and cleaned. The one with the cracked boot, i'm hoping does not need to come off. If that's the case, i'll slide it on from the other side.
I do have 4 NOS CVs if I need them.
I'm going to have the mufflers redone, so the question is, keep them silver or go black?
If I may
My vote is for silver in this case...
Once you go black ...
Tom wrote:Once you go black ...
You go deaf..... (Look it up)
Are the Kardasians deaf ?
http://www.youtube.com/watch?v=XnDjpUiKBmA
BTW... I just heard back from Jet Hot and they'll be redoing the muffler for free. So it will remain silver.
Personally, you should go back to pea shooters.
MrBreeze wrote:Personally, you should go back to pea shooters.
2006
Glenn wrote:BTW... I just heard back from Jet Hot and they'll be redoing the muffler for free. So it will remain silver.
http://www.jet-hot.com/jethot-warranty/
If you think your Jet-Hot exhaust coating isn’t living up to its billing, we’ll coat your part again for free. If it fails in the first year, we’ll re-coat your part and cover the shipping both ways. If the coating fails after a year, ship us the part, and we’ll coat it and ship it back on our dime.
Yep, we stand behind our work.
They sure do.
Before
After
turned out real nice..I can not believe the difference...WOW...
very cool...Matt
Looks good!
Big_kid wrote:Looks GREAT!
Fixed it for you!!!!
True!
Updates:
The tranny is almost done. He's waiting on the differential which is waiting for new clutch discs for the ZF.
It's been determined that the knocking sound is inside the case, so it's coming apart.
The car is still in my garage, Tim is having some issues with permits for the new shop.
glad its coming along!
Some good news...
The discs for the ZF rebuild came in so the ZF should be on it's way to Gary Berg this weekend. Then it just has to get in line so the tranny is finished.
They found the source of the ticking in my engine, it's the wrist pin on #1. Not sure if the rod needs to be replaced, but the case should not have to come apart. I'll know more after I speak to Art.
nothing but good news from this end. :D
Glenn wrote:Some good news...
Happy for your good news!
