Raj R: 73 181 Refurb
Re: Raj R: 73 181 Refurb
Nice OO9
Glenn wrote:Nice OO9
only temporary.
suffered one minor casualty during install, I hope my 019 is under warrenty
Warranty... yes, but not under "stupidity".Raj wrote:Glenn wrote:Nice OO9
only temporary.
No worry.. everything can be fixed.
Is that a bunch of fuz in the oilcooler? it looks almost blocked in the pic. not good.Raj wrote: old motor
good eye GA. I'll check the old cooler tommorow.
Hey Raj,
I was going through some links looking for a wiring diagram for my donor steering column, and found this tucked away-
http://www.1800vw.bizhosting.com/qa_gasheaters.htm
The conservatory link is now dead, but the other one still works.
I know I don't need to tell you this, but be careful with it.
thanks charlie... I'll check it out when the time comes.
I appreciate it
I appreciate it
Its been a while for the old 73. She has graciously stepped aside as the 74 slammed thing came into the picture this past March. She came up her plates. regi and insurance for the 74. Since winter is now upon us, I moved the 65 in winter storage and brought the 73 inside for some love. The plan will be a) repair the rear end damage that occured many moons ago by a PO b) weld in some metal to repair some holes c) and them paint. She will soon again be a driver so it wont be too fancy. I hope. Stay tuned.
She'll blossom like a spring flower from all the TLC!Raj wrote:Its been a while for the old 73. She has graciously stepped aside as the 74 slammed thing came into the picture this past March. She came up her plates. regi and insurance for the 74. Since winter is now upon us, I moved the 65 in winter storage and brought the 73 inside for some love. The plan will be a) repair the rear end damage that occured many moons ago by a PO b) weld in some metal to repair some holes c) and them paint. She will soon again be a driver so it wont be too fancy. I hope. Stay tuned.
Man... only 2 years in between posts. Now you're starting to be like me!
Looking forward to the pics & progress.
Yeah she was the beater for a year, then fell by the waste side while I built the green 74. But shes coming back baby!Big_kid wrote:Man... only 2 years in between posts.
I finally was able to play in the garage today, as I took the day off since I'll loose it by year end if I dont use it. The first area I'll tackle is the rear. If you have seen the car it has been rearend at some point in its live. The impact dished inward the rear bumper and apron and wrinkled both 1/4's. It was this reason that I was never planning on redoing this car. I thought about it a bit, and figured I'd give it a whirl..... worse case, I'd hang 74 style ear muffs on it to cover up the 1/4's. The car is going factory white in satin, so the body work wont need to be 'perfect perfect'.
Degreased the engine compartment last week. I'll need to replace all the shelves in here bc they are rotted away.
stress crease in under structure
1/4 damage,Should be flat like my donor clip
relief cuts on creases, done on both sides, and all three sides of beam.
grinded down
Jack
scissor jacks also
Some scrap from my den demo used to keep my vents straight
chains
fuego
Tug tug.
watch the gap
all nicey nice and straight 1/4's. yum.
apron is closer
grinded down
Jack
scissor jacks also
chains
fuego
Tug tug.
watch the gap
apron is closer
We want the cammo back !
Tom wrote:We want the cammo back !
Sorry Tom...no mo camo
She's going back to the factory blizzard white
she had love taps in both rear corners
a little heat
yanked the bumper and lid.....getting ready to message the rear apron
a little heat
- volksbugusa
raj
great solution in order to complete the repair...keep the pictures coming..Matt
Hats off to your creative solutions. Innovative, and effective. I like it.
- Matts70
- First Name: Matt
- Vehicle Year: 1970
Nice job Raj! love the ingenuity with your jack placment, chains etc. Good stuff bro!
thanks for the kind words team..... My MO is generally to make things up as a go along; 99% of the time it works!
Appreciate the encouragement!
yesterday I tried to tackle the rear apron a bit.
The rear light wiring runs through a tunnel in bw the inner and out wall. The outer wall was dented so I needed to remove the wire before I cut the inner wall. Unfortunately the wire was squished inside from the impact.
better
better
rot on shelves
snip snip
pesky critters within
parts clips await!
snip snip
parts clips await!
- volksbugusa
Raj...some great stuff you have going...love the solutions that you have come up with...Matt
- williamblanda
- First Name: Will
I'm siiiinking!Raj wrote:
Great work, Raj. Thing's looking great.
Stop FrackingGlenn A wrote: Carpet goes on the bottom. Unless it's a van than it can go on the sides and ceiling too.
Thanks Matt and Blanda. Its kinda a fun little project.
