74 Beetle
- volksbugusa
Re: End of the season
It really is amazing to look at your motor and to see no rust on the cylinders!! I know right now the wonder of it is a pain in the as_ but after everything is redone to your standards of today...you are going to be a happy camper...Again if you need help...just call me....if you need any parts sprayed..i can also help you...when it a little warmer.. Thanks for the helping hand....also wanted to tell you that I picked up a welded berg cooling fan as well...
Tranny is out, I just love IRS.
That POR15 really hold up after 11 years and 40,000 miles.
Parts everywhere.
And some broken parts when I drained the gear lube. I guess it was time.
Parts everywhere.
on the last pic... are those teeth off a gear?!!!
Sure are...
When you have a rigid mounted drivetrain, sticky tires, ZF LSD and a dual friction clutch... something has to give.
I'll talk to Gary about what can be done if anything this time around to prevent it.
- realbluefoot
- First Name: Jim
Yeah, there is something....just go stock, Glenn.Glenn wrote: I'll talk to Gary about what can be done if anything this time around to prevent it.
73 Thing
65 deluxe 13 window bus
Old VW's are like dead hookers at the beach...they're hiding everywhere and if you're lucky you'll find one that's not rotted away!
Trust me, i've destroyed my share of stock drive trains.realbluefoot wrote:Yeah, there is something....just go stock, Glenn.Glenn wrote: I'll talk to Gary about what can be done if anything this time around to prevent it.
Just heard from Gary Berg, he says the broken tooth looks like a spider gear. No problem since i'm replacing the differential anyway.
At least you're narrowing down what the issues are, good decision to investigate what was going on.
I'm guessing that would have caused a knocking sound.
The broken part is from the transmission. i have no idea what's causing the knocking in the engine.Glenn A wrote:I'm guessing that would have caused a knocking sound.
I started to make the crates.
It the ......... breather.AoT wrote:What is that tube that runs alopng the top of the tranny?
Notice the front of the trans is slightly different Aot. That is the Gene Berg 5spd GR is ALWAYS talking about. To be fair I would ALWAYS be talking about mine if I had one.AoT wrote:What is that tube that runs along the top of the tranny?Glenn wrote:
These are not going anywhere.
Also if you look at the transmission case, you'll notice that there's additional and thicker ribs. It's a Rhino case and much stronger than the stock case. They were made by VW de Brazil. It also has a HD side cover on the driver's side. That along with the Rhino case will prevent the case from cracking below the differential from side cover to side cover and through the drain hole which is a weak point.
I still have to remove the alternator stand and oil cooler. Then build the other 5 sides and they are ready to ship.
4 speed (left) Berg 5 (right)
Notice that the Berg 5 has a custom intermediate housing and nosecone. 5th gear is in the nosecone
Glenn wrote: 4 speed (left) Berg 5 (right)
See it always pays to ask questions, just learned something new. Thanks for the visual!
Thanks for the quote.AoT wrote:Thanks for the visual!
I'm always scared getting a visual from Glenn. You never know what might show up.
One down and one to go.
Glenn wrote:One down and one to go.
Looks like you've done this before.
How you shipping these GR? What carrier? And what are the costs estimated at?
Not sure yet.
Jeez you could have almost fit the whole car in that box. How much do they charge to ship air?
- volksbugusa
glenn
looking nice and safe....you will not have to worry about the box not making it there...
and that is a good thing...
Going by truck.Glenn A wrote:Jeez you could have almost fit the whole car in that box. How much do they charge to ship air?
Yes it's over sized but I have to put a few things in and it's only going to add $20 to ship for the extra space.
So you going to put that temp stock engine in for the duration of the repairs?
