Page 9 of 19
Re: End of the season
Posted: Wed Mar 07, 2012 5:03 pm
by Glenn
So i spoke to Art, one of the wrist pin clips broke and the wrist pin walked out and was touching the cylinder wall. He found the broken clip and will replace the cylinder and piston. There's no other damage.
Posted: Wed Mar 07, 2012 5:39 pm
Damn. What's your view on factory wrist Pins vs Teflon buttons? Anyone else have an opinion?
Posted: Wed Mar 07, 2012 5:48 pm
by Glenn
Raj wrote:Damn. What's your view on factory wrist Pins vs Teflon buttons? Anyone else have an opinion?
This was not a factory wire clip, it was a high quality internal snap ring.
SH!T happens.
Also the ZF is done and will be shipped today. So the tranny should be done soon.
Posted: Wed Mar 07, 2012 6:01 pm
Interesting. Good thing you trusted your ear and yanked the motor. Keep us posted
Posted: Wed Mar 07, 2012 6:08 pm
by Glenn
3 years ago I worked on a engine that locked up. Once I disassembled it I found one of the wire wrist pin clips was missing and the wrist pin gouged into the cylinder way. There has a deep gouge and the pistons was partially melted from the heat. Also the connecting rod and crankshaft were warped and blue from the heat.
I was lucky that I was close to home. I drove maybe 1.5 miles with the sound.
Posted: Wed Mar 07, 2012 7:25 pm
by BusBq Bill
Glenn you say the wrist pin clip was "High Quality" ??
Posted: Wed Mar 07, 2012 8:57 pm
by Glenn
BusBq Bill wrote:Glenn you say the wrist pin clip was "High Quality" ??
Yes... it was, but shit happens.
BTW... i've never had a stock wire clip break and i've done many engines.
Posted: Sat Mar 17, 2012 1:14 pm
by Glenn
Engine is done and will be shipped back Monday.
I just gotta wait for the tranny.
Posted: Fri Mar 23, 2012 12:56 pm
by Glenn
It's back.
Thanks to "Type 2 Jim" for bringing his pickup truck.
Re: End of the season (it's BACK)
Posted: Fri Mar 23, 2012 1:13 pm
by MrBreeze
It's been 15 minutes, is it running yet?
Posted: Fri Mar 23, 2012 1:58 pm
MrBreeze wrote:It's been 15 minutes, is it running yet?
Lol
Posted: Fri Mar 23, 2012 5:00 pm
by Tom
Is that Ed unloading that ?
Posted: Fri Mar 23, 2012 5:09 pm
by Glenn
Ed who?
Anyone need a gently used crate?
Posted: Sat Mar 24, 2012 1:02 pm
by B MAN
gently used lol
Posted: Sat Mar 24, 2012 7:02 pm
by AoT
Did you get a warm fuzzy feeling all over?
Posted: Thu Mar 29, 2012 8:15 pm
by Glenn
Tranny is done.
Apart
Had the ring, pinion, mainshaft and gears Cryo'd
ZF LSD rebuilt by Bruce Tweedle
Test run in a jib
Al ldone and now with two vents so no more gear lube puking out.
Posted: Thu Mar 29, 2012 9:43 pm
Damn, Pretty bad ass.
You going to reprint that side cover?
Posted: Fri Mar 30, 2012 7:40 am
by AoT
Glenn wrote:Tranny is done.
ZF LSD rebuilt by
Bruce Tweedle
is this name for real?
Tranny looks like its ready to be christened!!
Posted: Fri Mar 30, 2012 8:37 am
by Kermit
Nice photos, I can't say I've seen many half-assembled transmissions.
Posted: Fri Mar 30, 2012 4:18 pm
by Big_kid
I can handle a Chevy RWD automatic teardown/rebuild, but stickshifts have always intimidated me. This build looks really impressive!
Posted: Fri Mar 30, 2012 5:51 pm
by Glenn
I got the engine tin back from the powder painter and can start putting the engine together.
Posted: Sat Mar 31, 2012 5:37 pm
by Glenn
Its a rainy day so i got busy.
I decided to get part of the carb linkage powder painted to match the tin.
Also had the intake manifolds media blasted and powder painted... clear. I think they look great.
Engine on the stand and the oil cooler on.
Full flow fittings.
Close up of the return fitting.
Pulley tin clearanced for the return fitting.
Hoover Bit on the oil cooler
I switched from the old BP6ES which has a 13/16 head to a BCP6ES which has a 5/8 head.
Cylinder tin
Very small gap
Head ports
Sleds
Small tins usually left off.
Header on.. what a PITA to get everything lined up.
Type 126 Industrial tins
I also removed the distributor, replaced the points, reshimmed the shaft and tested on my Sun machine... works like new.
Posted: Sat Mar 31, 2012 7:01 pm
by Brown
Someone was a busy man!!!
Posted: Sat Mar 31, 2012 10:47 pm
by AoT
I did some tin work today too. Got mine sprayed black satin and for a pop of color sprayed the coil RED!!
Also putting things back together. it was that kind of a day
Posted: Sun Apr 01, 2012 7:50 am
Nice pics glen. Good move on clearing the intakes. When they are raw aluminum they really tend to absorb oil and grime as you work your way around the motor. I never knew they could powder clear!
