Posts: 3215 Joined: Tue Sep 09, 2008 4:20 pm
Post
by Glenn » Tue Feb 11, 2014 8:25 pm
JohnnyJet wrote: access my plugs and adjust the dual webers is impossible without them. l
Not true.
JohnnyJet
Posts: 41 Joined: Sun Dec 22, 2013 3:15 pm
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Wed Feb 12, 2014 12:11 am
You'll have weber window envy in 2 months
Posts: 1935 Joined: Tue Sep 09, 2008 8:03 pm
Post
by Raj » Wed Feb 12, 2014 7:22 am
JohnnyJet wrote: You'll have weber window envy in 2 months
Im very anxious to see these.....
Glenn wrote: I have to say, this "gruppe" is so much more than just a car club.
MrBreeze wrote:
This is the DVG board. The threads flow as they flow.
Posts: 1429 Joined: Tue Sep 09, 2008 5:23 pm
Post
by ObnoxiousBlue » Wed Feb 12, 2014 7:34 am
I got this, Glenn!
He's had the car for 40 years... I don't think two months will make him swoon!
LOL
Post
by Glenn » Wed Feb 12, 2014 8:22 am
I've had dual carbs since 1980. That's a lot longer than 2 months.
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Wed Feb 12, 2014 6:08 pm
I meant when ya see my car in 2 months when its done....lol
Im hoping to be completed by tax day. Id love to be done and at the march meeting.
leo
Posts: 20 Joined: Sun Oct 18, 2009 10:13 am
First Name: Leo
Post
by leo » Wed Feb 12, 2014 6:20 pm
Nice looking ride. Keep up the great work and I can't wait to see it done.
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Fri Feb 21, 2014 8:23 pm
Motor is done"
Post
by Glenn » Fri Feb 21, 2014 8:36 pm
Be careful with the serp belt. They provide no slip for the fan and even welded fans are know to explode if over accelerated.
Does it have flaps and thermostat?
Posts: 763 Joined: Wed Oct 01, 2008 12:25 pm
Post
by EDNCAROL » Sat Feb 22, 2014 1:12 am
Glenn wrote: JohnnyJet wrote: You'll have weber window envy in 2 months
Longer than Mike's been alive! Lol!
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Sat Feb 22, 2014 12:48 pm
Nope. Just went with the welded balanced fan and scat cool tins. External oil cooler, 5 qt pan.external oil filter.
Post
by Glenn » Sat Feb 22, 2014 2:13 pm
If the engine is built and tuned correctly you won't need an external oil cooler. Too cool is almost as bad as too hot.
Not trying to get on your case, but i've seen/built many engines and some things work better than others. Also what's easy isn't always what's best.
If your 1835 is built with the standard thin wall 92s, then you need it to run correctly or they will warp. OE German tin is the most important including running the correct Type 1 tin and shroud.. Even the small tins underneath by #2 and #4. And don't forget the Hoover Bit that fits around the stock oil cooler.
If you ever want to discuss the pros and cons, i'll be happy to do it in person.
When you install the engine, make sure you breakin the cam correctly. If you want, i have a bell housing and starter you can borrow so you can do the breakin with the engine outside of the car.
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Sat Feb 22, 2014 7:43 pm
Thanks . I appreciate it. Guy that built the motor has been drag racing and building drag motors for VWs for a very very long time. I have the utmost confidence in the build. I watched and helped every step of the way so I have no doubts about durability etc.
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Sat Feb 22, 2014 7:54 pm
I have a run stand so I will be doing the break in outta the car like you recommend.
Post
by Glenn » Sat Feb 22, 2014 8:46 pm
JohnnyJet wrote: Guy that built the motor has been drag racing and building drag motors for VWs for a very very long time.
I've known Joe since the early 80s. He built a 1776 for me back in the late 80s.
Building a drag race engine and a street engine that will last 100,000 miles are apples and oranges.
Like said, i'll be happy to discuss when we meet. It's just easier.
Post
by Raj » Sun Feb 23, 2014 7:14 am
JohnnyJet wrote:
Motor is done"
Looks super sweet. Can't wait to see that puppy stuffed into that 65
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Sun Feb 23, 2014 7:21 am
Thanks so much, I'm one of those guys that can never get info info and knowledge so your offer is very much appreciated and I look forward to seeing you and the rest of the group real soon.
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Sat Mar 08, 2014 7:53 pm
Body back on pan
Post
by Raj » Sun Mar 09, 2014 5:24 am
Looking good!
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Sun Mar 09, 2014 5:07 pm
Thanks raj.....it's so close I can taste it... Lol
Post
by Glenn » Sun Mar 09, 2014 5:11 pm
JohnnyJet wrote: Thanks raj.....it's so close I can taste it... Lol
Now's the time to slow down and not take any short cuts.
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Mon Mar 10, 2014 7:34 pm
I know, this is the time consuming part, the bolting of the pans, etc. Ive already test run and tuned the engine on the stand and its perfect. so now all my attention is on the body and pan. So far all is good. Im going over everything twice, fronto back and back to front...... I hope to be at the april metting.
JohnnyJet
First Name: john
Vehicle Year: 1965
Post
by JohnnyJet » Fri Apr 18, 2014 1:12 pm
Four days of progress and the motor is ready to install, the engine bay has been prepped and detailed. I got sidetracked by having to re-wire the headlights as the previous owner decided a 12v conversion is just changing the battery.....needless to say some wire melted. Soooo im hoping by may it will be on the road. The engine has been test run and is flawless. See you all soon
Post
by Glenn » Fri Apr 18, 2014 1:42 pm
Can't wait to see it in person.
Post
by ObnoxiousBlue » Fri Apr 18, 2014 7:23 pm
Get it meeting ready, then off to Litchfield with it in June!
