my project 71
found site postimg.org seems better/easier then photo bucket. so i changed my fuel pump 2 weeks ago Image and figured id change the oil Image and while changing the oil i found my oil leak https://s20.postimg.org/6elq62sx9/20170723_155519.jpg[/img] so i think ill try torqueing the heads /resetting the valve adjustment and dropping the timing and redoing the carb adjustment
Are you going to torque the heads for a reason or just S and G's ?
Be aware that the head bolts are known to pull out of the cases on these old motors then you are in a world of hurt. Ask me how I know ...
elrockk wrote:Does anyone here have a SUGARGLIDER or know someone that does . I have some Free stuff like a climbing tower /food /snacks and vitamins if anyone wants
https://longisland.craigslist.org/zip/d ... 59369.html
I have to admit I had no idea what this was until I saw it this morning.
im torqueing the heads because that seems to be my oil leak from the base of the jugs. i think its only 20 something foot pounds
yes that s the stuff im giving away Image had to put my buddy down and would like to hook someone up
Okay, didn't know that was you.
If it is leaking from the base of the jugs I doubt that tightening will stop it, the sealer is compromised between the jugs and the case. (Permagasket type sealer) As I said before unless it's a hideous leak I don't think I would risk it but that's just me because when I tried to fix my leak I ended up buying a motor. :oops:
i think 23 foot pounds should not break anything but i will eat crow if it does. ive also read that loose head bolts let the jugs go up and down and pound the case leading to engine damage. 23 foot pounds or bust
i just did an engine at work was 59 foot pounds plus 90 degrees then plus 60 degrees came out to 245 torque total
elrockk wrote:i just did an engine at work was 59 foot pounds plus 90 degrees then plus 60 degrees came out to 245 torque total
Was the case made of magnesium ? :D
got some time in on the bug gonna start and finish each corner one at a time Image Image Image Image got the new quarter panel and body tweeked to fit nicely hopefully more work this week
got some time in the garage today Image cut out the old quarter panel Image sanded drilled and punched wholes for spot welds Image and got a pretty good rough fit Image
i need to do some repairs to the infrastructure that the quarter panel welds to and fine tune the fit and spray some of the infrastructure with rust incapsulator while i have the panel off
i got the new quarter panel tacked in today Image Image Image
Nice work! Keep at it!
picked this up on ebay Image its for way down the line but the price was right. hopeing to get mexican fuel injection hard parts for xmas
Funny looking hair dryer.
i havent needed a hair dryer for some time now
elrockk wrote:i havent needed a hair dryer for some time now
As Bill Clinton would say " I feel your pain." :D
As Bill Clinton would say "I didn't have sex with that hair dryer"
Fixed for you.
photobucket fix worked on my thread Photobucket Hotlink Fix use at your own risk i havent been able to scan it for viri
more parts for fuel injecting the bug Image Image Image Image got fuel rail with 6 injectors and wiring for 50 bucks shipped. got throttle body with map/tps/iac/and a vacuum switch with wiring for 25 bucks shipped waiting on cb intakes for xmas
more parts to fuel inject the bug Image
layout to start making the intake Image Image
got some time today and cut out the end of the intake that will bolt to the throttle body Image
I wish I could keep up with your progress! My Astro van is kicking my butt these days.
yeah my daily has been nickel and dimeing me the last 3 months
