Orange Crush
Re: Orange Crush
Brown wrote:
Front
I think Benjamin Moore should use this as a testimonial for their product. Great transformation!!
Re: Orange Crush
Here's what the floor looks like with the patches installed! To patch the floor I have used a piece of my old yellow bug, a microwave oven, a Dell computer, an audio box and a piece of metal from Manny. It's like a quilt all melded together with rivets and welded.
Here's after a coat of Por 15
Re: Orange Crush
After the floor I pulled all the carpet out and the luggage area out because the stunk. Under the luggage area it had a lot of surface rust which I scrapped as best I could and covered it with Por 15.
Re: Orange Crush
Progress! Keep at it!
Re: Orange Crush
The magic of paint!!
I heard that if you tap a screw into the lid of POR15 to pour out the paint it prevents the lid from getting sealed shut. Well I tried it on a new can and it doesn't work. The lid of the can is so soft that the screw doesn't descend around the threads but just creates a hole as wide as the screw and if you tip the can over the paint escapes. Even tried different size screws, hole just kept getting bigger. :?
Re: Orange Crush
wow KEN! you have been busy my friend. Looks great!
Re: Orange Crush
Thanks Raj!! It looks ok from a distance, but the heater channels are still shot. hopefully this will keep some of the water out. I'm going to lay down some sound proofing and a cheap carpeting material from HD to cut down on some of the road noise and then that will be it. I used roofing tar all alnog the bottom to fill in the gaps between the metal and it doesn't look half bad either.
I still need a windshield and some door seals as well!
Re: Orange Crush
Last night i had a few minutes so i glued some 1/4 inch sound proofing/insulating wrap into the luggage compartment. I used #m Spray adhesive and so far it looks to be holding ok. Once of cover the car I'll cut some outdoor carpet to cover things up.
