according to this
i believe im looking at 'H" on there
tried tracing the wires i cant figure out these last few
which is coming off the turning signal signal harness
Save that job for a rainy day!B MAN wrote:
I'm not bothering with the windshield wipers yet.
Did you buy a new harness ?B MAN wrote:I rewired the car, so I'm trying to get the turning signals for the first time
my assumption is
1- power
1- ground
1- blinker relay
1- high beam relay
just don't know which wire is which
Brown is normally ground. Your wiring diagram shows i brown going direct to ground. The other going to the ground on the speedo and the last brown going to the horn circuit, through a plastic connector.B MAN wrote:the 3 brownish ones r the tricky ones
