66 deluxe bus 13 window
Re: 66 deluxe bus 13 window
Dave knows cheap !
I resemble that remark !
- First Name: Steven
- Vehicle Year: 1957
ObnoxiousBlue wrote:You could've driven it sans pedal. It takes a good ear, and a gentle hand. But, I've done it in that same predicament.
Can you elaborate on this? This is my first time with a standard transmission
1966 13 window bus
The other night I pulled out the cutch cable that I thought was going to be broken. Turns out to be in almost perfect condition. Did a lot of research and I think it's my throw out bearing / operating shaft
Tomorrow I'll pull the engine and investigate
1966 13 window bus
Did you check the arm on the clutch fork? Is it just flopping around, or still hard to move fwd? Should be super hard to move fwd with the engine in.
You def heard a ' snap' right? What does the engine sound like when it was running? You heard any ' shit' floating around in the bell housing?
When installing the motor did you replace the throw out fork? Throwout bearing? What clips did you use on it.
Im guessing the TO bearing came loose. If so, you sometimes hear some pretty bad noises when you push the clutch pedal in. Sorry bud.....
Took the engine out on Sunday and found the fork broken. Already got the fork out and have a new fork to put in. Will install it Thursday morning when I get off of work.
Fixed my wheels today. A bunch of clips that hold on the hubcaps broke off.
1966 13 window bus
Impressive.....! Never seen one snap like that.
Nice save. and glad you were close to home.
Usually they just bend.
agreed.... seen many a bent ones. And thats usually from a failed clip. Could have been just a perfect storm event here, where the clip let go, and the bearing was wedged in the perfect spot.... SNAP!Glenn wrote:Usually they just bend.
That has to be one of the cleanest bell housings I've ever seen.
Tom wrote:That has to be one of the cleanest bell housings I've ever seen.
The bus is alive again. Replaced the fork and other parts this morning and was able to take it for a quick test drive
1966 13 window bus
Glenn wrote:Tom wrote:That has to be one of the cleanest bell housings I've ever seen.
Yeah but he drives his .
Tom wrote: Yeah but he drives his .
Mine drives, all you have to do is turn the key. I just have better things to do with my time.
Installed Blazecut over my engine and replaced the fuel sender in the tank so many finally have a working gas gauge. Have a couple of small things on the list to finish before next weekend at Busses by the Duck
1966 13 window bus
Haven't updated this is awhile.
Scored a rear bumper with the overriders. The front will be matching soon.
Was scheduled to use the bus to bring the bride and brides father to the church for my cousins wedding on 7/8. Only to find out a couple days before that i was having alternator issues and wiring issues. Replaced the Alternator and painted the interior between the headliner and door panels. Was full of surface rust and 50 year old glue. Stripped it and sprayed a couple of layers of white paint.
Also recently installed new shocks. Drives like a totally different bus.
Plan to adjust the valves, sync the cards, and adjust the timing this week
Upcoming plans
-put together and paint front bumper
-strip floors / por-15
-paint new pop out windows and install
-new wiring harness
-Stereo system
Upcoming shows plan on attending
-Terryville
-NYC Traffic Jam
-All Air Cooled gathering
-Transporterfeast
Upcoming plans
-new wiring harness
-Stereo system
-Terryville
-NYC Traffic Jam
-Transporterfeast
1966 13 window bus
The laundry list never ends, nice to see you're still going on it.
I should be at those shows too... Terryville is a 50/50 I believe I'm already off work - and if so will go. But won't be taking time off for it.
That said I'll definitely be at the others which are already planned for in my vacation time.
Try to make it to Salem for camping pre-Transporterfest. I've been camping in Salem for years - even before the pre show camp event came to town. Salem is easily my favorite place to visit. Tons to see and do, not to mention I love the history. It, with VW buses? It's Awesome.
ObnoxiousBlue wrote:The laundry list never ends, nice to see you're still going on it.
What day are you going to Salem? Have to see if I can take vacation time for that weekend or mutual off. It's a tough weekend to get off
1966 13 window bus
I usually head up about the Wednesday before. I already out in for my time, I don't recall if I put for Weds or Thurs - I'll have to double check. Either way, I've been going to Salem for years, it is awesome in October and easily one of my favorite - if not my favorite a place to go. Tons to see and do, even beyond the usual holiday antics. Make sure to plan for the drive as there will be traffic and leave yourself plenty of time to explore.
Been working on a couple small project lately
Changed mirrors
Added a tempory wood long interior panel to cut down the nosie
In middle of redoing the 6 pop out window
Dropped off a tranny in south jersey to be rebuilted (not the one currently in my bus)
Changed mirrors
1966 13 window bus
who did you use for the tran rebuild? I'm looking to do the same for a 63 bus.
good to know.... thanks. I await your feedback on him.nyr208 wrote:Matt Steedle in Atco Nj. He is on facebook
the Bus is in the garage and the winter projects have started
Currently in middle of redoing the 2 front seats. I have the passengers frame torn apart and now stripping the old paint/ rust off. will be repainting then putting new horse hair/covers on
Winter Projects
- front seats
- move oil filter
- strip and repaint/por15 front cab area
- Engine gauges
- new vent rubbers/ door seals
- respray bumpers
- rewire radio/cb radio
Winter Projects
- front seats
- move oil filter
- Engine gauges
- respray bumpers
1966 13 window bus
