69 baja
Re: 69 baja
vwbri wrote:The front tires? look at the size of those rear tires!
Raj and I had a conversation about his fronts being a little to big . Thats why I pointed them out . This car is super nice if I ever did one this is exactly how i would build it .
Re: 69 baja
yeah GA, that what I'll run in the front.
Re: 69 baja
looks like you have a little work ahead of you...wiring harness can be fun....clean the fuse panel really good with metal contact cleaner...RADIO SHACK...
anyway looking real good ....but then again you do nice work.....
did you buy a new truck yet?
Re: 69 baja
i took a mini wire brish to each contact both on the fuse side and connection side to get the contacts super clean. Thanks for the support matty
Re: 69 baja
brake time
old drums
brake shoe with no sole
bye bye
the boss looking on in approval
where's matty's machine when you need it
73 ghia disc set up paint with eastwood rust encapsulator
inside of old shock seized to shock mount
vw discs spindle
yes... i cut them you bastards
sitting pretty
ta-da
Re: 69 baja
Raj wrote:brake time
NICE!
Re: 69 baja
rear brakes
drumless
i love fire
all new crap
much easier to work on
needs 3x3's i think
nose in, for hardlines up front and wiring
Re: 69 baja
You've been busy.
Re: 69 baja
i was too nice out today, i had to be out there
Re: 69 baja
Raj wrote:i love fireImage
I love it ! don't put it out grab the camera ! I sence a new thread "Rusty bolt fires" . I had a spindle fire today in the garage I put it out before I got a chance to take a shot .
Re: 69 baja
That is an ugly engine lol...
HI STOLI!
Raj, I cant wait to see this thing... It better be at the next meeting.
Re: 69 baja
that engine was just thrown in there to see if I can get her running. I have another one lined up for the baja
stoli says hi too
Re: 69 baja
where's the marshmallow's...........Raj still looking for ball joint arms.....to press out old ball joints......let me have have yours......i will remove the ball joints for you :)
Brakes are really looking good..............
Re: 69 baja
Matty,
they are yours.
Re: 69 baja
started installing the wiring harness. I noticed the ignition switch is fried out so I'm looking on TS for one. Mostly plug and play, and pray.
Buttoned up everything down low, replaced the master, new blue hoses, two new hard lines, installed dampner. I decided to spend the money on new calipers so they should have been shipped today. I have new rubber hoses, but can install the rest from the underneath later.
Re: 69 baja
last year, i bough por 15's tank sealer kit and did my 65, thing tank, and the baja tank. ( this was done in my kitchen..... good times, good times... before i was married) The stuff is great, dries rock hard and coats everything very nicely. It got into some of the threads at the sender so it was time to clean it up
Live and learn. For those who went to etown last year with me...... this is the $3 part in your tank that you need.
67SAMBA
First Name: Joseph
Re: 69 baja
Post by 67SAMBA »
Baja looks great, can't wait to see it. Keep up the good work, and post more pics.
Having a good time with my VW!!
Re: 69 baja
volksbugusa wrote:clean the fuse panel really good with metal contact cleaner...RADIO SHACK...
When I worked at Monkey Ward as a service tech, they were too cheap to buy us contact cleaner. We'd use ketchup packets from Mickey D's. When tuning up a lawn tractor I'd pop off the ignition switch connector, do the tune up, then blow it out. If I had anything on hand to neutralize the acid I'd use it. Soaking the copper connections in the acid cleaned them up really well. Put a drop on a tarnished old penny for 15 minutes & see what it does.
Baja's looking good, btw!
Re: 69 baja
i noticed the ignition switch was all burnt up in this bug.
so I bought one off TS. Turns out we had the matching door handles also, ..... score.
i slapped in the ignition switch, and door handles tonite
Re: 69 baja
thanks NICO for this part. This is a gas door release that was used in 69-70 ( + or - a year)
Threw that in too.
Re: 69 baja
Bought new calipers and pads off TS, as well. They came today. Mated them with new rubber hoses for an all new brakes system for this baja
Re: 69 baja
When is this going to hit the road ?
Re: 69 baja
eehh...... not really in a rush, but prob with in a month.
NicoSB
Re: 69 baja
Post by NicoSB »
Looking good Raj, can't wait to see the finished product. When you plan on having it ready for the streets by?
Re: 69 baja
bleed the brakes tonite. Nice pedal.... thats good
i had to glue down the rear headliner , cut out a few holes and then slapped in the rear door panels
