Nassau County Machine shops
Re: Nassau County Machine shops
is 8.5:1 advisable for what im building? or let the shop figure out what CR i should go with
Brown wrote:Let me know when the Tech Session will be I'll stop by!
i keep forgetting to get that light holder off of you also
see u there!
B MAN wrote:is 8.5:1 advisable for what im building?
What are you building?
Is it a stock engine with 87mm cylinders?
8.5:1 it is!
all done?
Raj wrote:all done?
I want to hear that baby running!
one of the rocker arm shims was broken and being held together by the tension on the assembly..
i made a phone call, there might be two waiting for me in deer park, waiting to hear back from the guy.
im hoping to get it running by spring, im changing the mounts to rhino before i put the motor back
B MAN wrote:i made a phone call, there might be two waiting for me in deer park, waiting to hear back from the guy.
Is that the same guy that did a sh!t job on your floor pans and charged you a small fortune?
Rocker arms on 1 side are really tight up against the valve springs, i don't even have the adjusters in yet
torquing everything to spec, had a long day gonna go for a drink n head to bed
