Re: End of the season (it's BACK)
The rebuilt axles were packed with grease so when I installed them it squeezed out and had to be cleaned up. Working or cars is always messy.
Those axles were packed like cream puffs. One step closerGlenn wrote:The rebuilt axles were packed with grease so when I installed them it squeezed out and had to be cleaned up. Working or cars is always messy.
You had the same with yours... when you tighten the bolts, it oozes out like a jelly doughnut
MMmm.... doughnuts (couldn't find him eating a doughnut)
Can't wait to see it back in one piece
If only my engine compartment was Half that clean . . . . . . . . . . .
"Raj wrote:
idle shmidle, feathering the throttle is always a fun game."
So close...
I just need to borrow a second floor jack so i can raise the car and then shove it in.
- volksbugusa
looking real good Glenn....It is a lot of work...Matt
I could stop over tonight with my jack if you would like?Glenn wrote:So close...
That could work. Give me a call later.Brown wrote:I could stop over tonight with my jack if you would like?
I had to drop the Civic off at GT to get a new mirror installed so I had the kid give me a ride home and I borrowed a 2nd floor jack.
So I slammed it in and i just have a few more things to button up and then it's ready to fire up.
TCB...
Basically I need to install the muffler, banjo fitting to the carbs and put oil in it.
TCB...
I love that car... Hope I have something that nice one day.
Glad to see it coming back together.
It runs. Still gotta dial it in and button it up. Soon, very soon i'll be terrorizing the streets again.
A real one man show. Looks like its ready for action. Nice job.
Not yet... I still have to get it running right. then i have to break in the tranny and finally bring it to GT for tony to tweak the carbs.AoT wrote:A real one man show. Looks like its ready for action. Nice job.
Re: End of the season (it runs again)
Good work glenn. Can't wait to barely hear this beast pull up, but def hear you pull away!
- Kermit
- First Name: Kermit
- Vehicle Year: 1969
Nice! The timing on all of this is pretty perfect. Wish this board had a thumbs up icon...
Was that noise at the end the fan belt or something else?
Glenn wrote:DVG, we see all.
Fan belt... needs to be tightened.Kermit wrote:Was that noise at the end the fan belt or something else?
Mine are SBD
Did some adjusting on the linkage and it's close enough to let Tony do the fine tuning.
I found the source of the rattling I heard, I never attached the muffler straps to the rubber hangers and they were jingling.
I stepped on the clutch to run it through the gears with the wheels off the ground to get the gear lube on all the parts. It's way out of adjustment and I didn't want to get under a hot engine.
Running much better.. not prefect, but soon.
I know this cool video that shows you how to do thatGlenn wrote:Fan belt... needs to be tightened.Kermit wrote:Was that noise at the end the fan belt or something else?
On the road again... took a short trip to GT. No leaks and uneventful.
Nice to see it soaking up some sunshineGlenn wrote:On the road again... took a short trip to GT. No leaks and uneventful.
Re: End of the season (On the road again)
It needs a wash. I never got to it last Fall when i took the engine out.
I guess the body work will have to wait for another day and time!!!Glenn wrote:It needs a wash. I never got to it last Fall when i took the engine out.
