Tom wrote:Yeah that Berkeley sticker has got to go.
Stinking hippies... literally, they smell.
this is the one that came with the car Image
Tom is going to have a stroke when he see that.
Glenn wrote:Tom is going to have a stroke when he see that.
Feeling the "Bern" 70's style. Some things never change.
got back in the garage today and replaced the transmission mounts Image tried replacing the front mount with a urethane but it wasnt a direct fit so ileft the used ok one in
gonna replace the fuel line and put the engine back in so i can drive it in and out of the garage instead of pushing it
Good to see you're still on it and making progress. Don't all the transaxle mounts need to be the same type? I thought mixing them would cause premature failure?
No... but i would use stock. The red ones tend to come apart over time.
yes i think im going to try to find OE ones the ones i took out were bad but for being 30-50 years old looking pretty good
yes i think im gonna try to find a pair of OE mounts the ones i took out were probably original. one was bad the other just old but for probably 50 years old not bad
got back in the garage today replaced the fuel line Image with nicopp alloy back to front Image made a hole in the tunnel Image
got the line thru the hole Image does anyone have a picture of how the fuel line ends at the back of the car Image
figured i would change the front engine seal while i have it out Image and clean the front of the engine Image the flywheel/clutch/pressure plate look good so i scuffed them up and reinstalled them Image Image
and does the fuel line going to the fuel pump run thru the dog house i thought i took pics on dissassebly but i cant find them
Mine does not. It's also a buggy, so not everything is stock though.
elrockk wrote:and does the fuel line going to the fuel pump run thru the dog house i thought i took pics on dissassebly but i cant find them
The metal line that goes to the pump from the front of the engine ( front is front) generally wraps around the 3/4 side of the motor and travels to the pump near the intake. The ends have the rubber hose where it connects to pump/ line from tunnel.
thats kinda what i remember taking off but i asked because there are holes on both sides of the dog house in that area. around it goes thanks guys
got the fuel line thru the tunnel done today Image Image Image Image
Great job on that. I know that wasnt fun.
some new curse words and plan D got it done
got the engine in today and new fuel line on engine side Image Image
Keep at it! You'll be driving this in no time.
Good day in the garage today i got the heater channels welded to what ever these are Image Image not my best work but moving foward Image sanded the top to spot weld the pakage tray in Image new rubbers front and bImageack
Image newbrake lines from the resevoir to the master cylinder Image Image Image got front brakes bleed but no luck with the rears i have a vacuum bleeder at work ill try that tomorrow
and a newsteering coupler Image
