Rob's 1977 Fatty Camper
Re: Rob's 1977 Fatty Camper
The old KMart lot on Montauk highway. 7-10am.
I may be moving equipment upstate, so I won't know if I will be around until Friday.
Found an old picture of my first camper in 1989. It's a '71, and yes, I know before you say it lol
Four years later and the mystery whistling is solved! It was a slight break in a vacuum line.
Now if I can just get the Tiguan sorted out lol
MrBreeze wrote:Four years later and the mystery whistling is solved! It was a slight break in a vacuum line.
I thought you said there was a knock ?
Knock knock? Who's there?
Tom wrote:MrBreeze wrote:Four years later and the mystery whistling is solved! It was a slight break in a vacuum line.
There was. the hose finally broke
If you are going to redneck repair a hole in the bus, at least have the class to use the right color tape.
Rob, is there holes from rust or is the seal bad? Buy a seal, I'll come over and we'll get it installed. Easy.
Rust needs to be fixed first then seal.
Mucho rust
BusBq Bill wrote:Rust needs to be fixed first then seal.
I would have went a shade darker with the tape .
Just throwing it out there......I'm looking for a Idle Air Control Valve for my bus. Can't even find a part number for it
doesn't Tom have a complete FI system that he's been talking about reinstalling for past 20 years?
It's only been 14 years !Glenn wrote:doesn't Tom have a complete FI system that he's been talking about reinstalling for past 20 years?
Ley me look Rob, I may have one or 2 ?MrBreeze wrote:Thanks
Finally got the screws off of the camper luggage rack. Gonna need the large tub of flex seal
I used that on my gutter seams... no more leaks.MrBreeze wrote: Thu May 23, 2024 6:09 pm Finally got the screws off of the camper luggage rack. Gonna need the large tub of flex seal
Better than Henrys.
pics ?
I had to get up early to get the Tiguan inspected. Now I'm too tired and lazy to work on the camper although I really need to deal with that leak. Ok, tomorrow. I mean it.
Are you sure you weren't a pug in a previous life?
Wouldn't surprise me.
So I'm guessing I found my leak
So I fixed it back to factory standards
Good for another 10 years at least
